How to run dialog VIs on a RT Target
I'm new to the labview Real Time programming.  I'm having trouble trying to get the "read spreadsheet" vi to work with it.  I need it to prompt the user to select the file but when I run the VI under the real time target I get "Error 43: User canceled the operation".  I've tried using the RT communication tool to convert the VI into a RT VI but this still doesn't work.  I'm running Labview 7.1 along with the Real Time module.  I know this probably has a simple solution but I just don't have enough experiance using the RT system and no one here at work does either.  Any help would be greatly appreciated.
(4,026 Views)
Hi There:
I am attaching a knowledgebase that I think will answer your questions.
http://digital.ni.com/public.nsf/websearch/A4187144E7196DEB86256C8B006E3C21?OpenDocument
Best Regards,
Jaideep
(4,001 Views)
Thanks a lot!! This looks exactly like my probem.  Thanks again!
(3,992 Views)
Acually, I think the "list directory.vi" is not available in Version 8.0.
So I would be really grateful, if anybody could help me with the same problem: I get error 43, when I run my VI in real-time. Without real-time, the error 43 doesn't appear.
I am looking forward to your response!
Rainer
(3,686 Views)
