How to use a PXIe-6569 like an NI-6585B with FlexRIO FPGA Module?
For my latest project I decided to try the new (new to me at least) PXIe-6569 & TB-6569 to generate a 100MHz clock along with other user controllable LVDS outputs.
The socketed CLIP is significantly different than what I'm used to with a PXIe-7971R & NI-6585B combo.
The blocker for me is that the PXIe-6569 forces me to use a Tx Clock in my timed For Loop.  For some reason the CLIP limits the Tx Clock to 150MHz, which will result in a max 75MHz LVDS output clock I can generate.
Hacking around in the CLIP's XML I can see the max Tx Clock value is 150MHz... I'm not an expert in customizing CLIPs but would it be as easy as updating the XML to 200MHz, or do I need to make sure this change doesn't cause issues back in the original VHDL?
Or is there just a simple CLIP that already exists that is similar to using a FlexRIO board with an NI-6585B that's compatible with the PXIe-6569?
Thanks in advance for your help!
Ted
(865 Views)
Accepted by topic author Tedster
Was able to talk to our local Field Applications Engineer and he recommended using the SerDes clip instead of the Socketed clip.
With the SerDes clip, you can write an 8 bit value for each channel and it gets streamed out at each Tx Clock cycle. Or maybe a better way to say it is that 8 bits is streamed out each Tx Clock cycle.
So to generate a 100MHz clock output, I can write the value 0xAA and set Tx Clock for 25MHz.  The resulting output for my desired channel is a 100MHz clock (verified by measuring with a scope).
Thanks Kyle Mozdzyn for your help!
(815 Views)
