I am trying to acquire pulse signal (TTL 0 ,+5v) using parallel port (SPP 25 pins) on pin 12
The state register adress is 379h. When I run continuously this VI, the value diplays 78 and 58 periodycally.
I think that 0 correponds to 58 and +5v correponds 78. Is this correct ?
So my questions are:
1) How can I do to read only pin 12.
2) How can I do to display graph of a pulse signal (TTL 0 +5v) from value.
I attached the I am using.
Thank you in advance
(3,776 Views)
If you get an accurate representation in LabVIEW of the two different states, simply mask (logical AND) the number for the bit corresponding to the pin you are interested in. Doing a logical shift of the masked value will give you a 0 or 1 which you can plot on the graph or chart.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,776 Views)
