I want to use debounce filtering for the digital trigger on my CompactRIO device
I have a compactRIO system that I use for cylinder pressure data acquisition in engine applications.  I trigger the start of acquisition with a TTL pulse from a shaft encoder at a fixed engine crank angle.  Sometimes I get false trigger signals from noise on the line and I am trying to apply a debounce filter to the trigger (9401 unit in slot #5 of a 9172 chassis).  when I try and use a property node to turn on the debounce filter and set the filter constant, I get an error and the triggering doesn't work.  Its not clear to me if you can use the debounce filter for this device for the start trigger.  Any ideas?
(3,571 Views)
hiltnerj,
Are you sure you mean the 9172 chassis?  If so this is a CompactDAQ chassis, not cRIO.  You might consider posting your question on the MultifunctionDAQ board,  you might get a bit more help there.
Message Edited by crackerjo1 on 05-29-2009 01:10 PM
(3,548 Views)
Thanks, you are right, I have a compactDAQ not a compactRIO (typo on my part), I'll try the other location.
hiltnerj
(3,544 Views)
