Add 3d object without parent/child relation.
I have a 3d picture control scene, I have two objects in it, but when I created the scene I had to use the add object invoke node to put the objects in the scene, so there is a parent/child relation between the objects, that means that if I move the parent I also move the child object. Is there a way to create a scene with multiple objects without the parent/child relation.
Thanks.
--Luis
(3,488 Views)
Accepted by topic author Luis_R.
Hello, I solved this by first moving the objects and then adding them to the scene. --Luis
(3,471 Views)
