Communication between cRIO-9014 ethernet Port and FX3U-Enet ( Mitsubishi)
Dear all,
I have to communicate Mitsubishi FX3U- Enet with cRIO-9014  on ethernet.
FX3U-Enet is ether net module. This module can communicate the third party on therner.
What is the default Ethernet paremet of cRIO-9014.
What is default Ethernet IP aaddress of it.
 Which Software is use for configuring cRIO-9014. How
Is any one have develop sample program for cRIO-9014 communication with 3rd party
Govind l. lathkar
(5,082 Views)
There is no default IP address of the cRIO. You can assign one statically or dynamically. And, then use the TCP/IP nodes to communicate with your ethernet module. There are examples in LabVIEW's Example Finder. The software you will need is LabVIEW, LabVIEW Real Time and the NI-RIO driver.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(5,079 Views)
Do you know what ethernet protocols are supported on the MILSEC-FX3U?  I know the FX3U supports Modbus RTU on the serial port but I can't find any info if it supports Modbbus TCP on the ethernet port.
(5,070 Views)
I wouldn't be sure of that. You will need to verify that with the manufacturer of the device. And, remember, it is possible to communicate with a CompactRIO as a Modbus slave either through the built-in serial port on the chassis or through the NI 987x module. Have a look at this article and the links that are mentioned in it:
Can I Perform Modbus Communication with a CompactRIO and an NI 987x Module?
Adnan Zafar
(5,068 Views)
