USB-6251internal MHz timing
I have borrowed a USB-6251 DAQ to drive a stepper motor. The data sheet says that this DAQ is capable of MHz timing for digital IO. I have tried writing a simple programme (attached) to set the motor ENABLE and PULSE pins hi, and then send pulses to the PULSE pin using a "timed loop with frames" to set the PULSE pin hi and lo alternatively.
I would like to know:
1. How to setup a MHz timebase for the timed loop (both internal and external, and which of these options is recommended)
2. How to insert a wait function of microsecond order in the timed loop such that the pulse duration may be controlled (or any recommended alternative method)
Many thanks...
Jordi
(3,136 Views)
Duplicate post, let's consolidate this here.
John Passiak
(3,116 Views)
