IO Synchronization in FPGA module PXI-7833R
Dear all,
        I am using NI PXI FPGA module, PXI-7833R. Which is having 96 Digital IOs. In my application i want to synchronize all IOs, and generating PWM waveform with user diffined  phase difference. I tried to run each IO in separate while loop but it is creating synchnonization problem. Is there any way i can synchronize and generate PWM out put with phase shift.
--Vishnu
(4,363 Views)
put all of yor pwm generation code in the same loop so all the IO get written at the same time.  I would write a subvi like the image below then put as many instances of this in the loop as you need.  This example has phase control and a midpoint trigger (you may not need the trigger).
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(4,352 Views)
Dear Steven,
         Thanks for help. One thing i would like to know that, this will be like parallel loop only, Is it? As i understand  if we make subvi and use it in a single loop. It will work like parallel vi for each IO in a one parent loop.
         Second thing i want to know that this scheme, can i use for simple Digital IO cards?
--Vishnu
(4,312 Views)
If you make this into a sub vi, set the vi properties to "reentrant execution".  Then make a copy for as many channels of PWM you need.  Then they will all run in parallel.  you can place them all in side of one loop.   Yes you can use a simple DIO module.  The only limitation of course is the speed of the DIO module.
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(4,290 Views)
Thank you very much. Presently the system is in used. I will try this option and come to you again.
--Vishnu
(4,258 Views)
