Install software on CompactRIO 9033 through NI Max
i want to update an cRio 9033 with firmware version 7.1.0f0 over NI max. In NI Max under "Remote systems -> targetXYZ -> Software" i can see that there are several packages installed on the cRIO like NI-RIO 19.1, NI-XNET 19.1.0 etc. . On the Windows notebook i already updated all the packages e.g. there is a NI-XNET driver 19.5.0 installed. I can't update the packages on the cRIO and under custom install it says translated into English something like "Available versions on the host: none".
(1,977 Views)
Firmware updates should not be done via "Remote systems >> targetXYZ >> Software"
On the system settings tab, there is a button for "Update firmware" near the bottom. Use that instead.
Hope this helps!
-Hafiz
(1,912 Views)
