Interchannel delay
I read here and in other documents that a higher interchannel delay may correct multiplexed measurements for various reasons. Does this apply to a 9205 cRIO module? How can i increase its interchannel delay?
(3,764 Views)
You can apply the interchannel delay at your 9205 module.
In your Labview project, right click on your 9205 module >> Properties. Increase the value in the Minimum Time Between Conversion box as you like. Remember that the sample rate is linked with the interchannel delay, so if you increase the int. delay, the sample rate decrease.
Ciao!
______________________
Simone S.
Academic Field Engineer - Med Region
(3,740 Views)
Thanks, i'll try when i can. If i change that setting, do i have to recompile the FPGA VI that reads the module?
(3,738 Views)
Yes, you have to recompile the FPGA.
Ciao!
Simone S.
(3,736 Views)
