Interpolation on the FPGA
I would like to smooth motion of my linear motor. For example I would like to run a program on the cRIO in scan mode let say 1ms scan interval and then do interpolation between output points (for example from sin wave) on the FPGA scan interval 100us. I wrote little programs but my linear motor does not move at all. I cannot find where I made a mistake or/and something is missing.
Any help will be approciated.
I put in the attachment my FPGA file as well as host file which I run on the cRIO.
Thanks.
Kamil
(4,930 Views)
Dear Kamil,
Is it possible to see your labVIEW project explorer file?
Kind regards,
Alex
(4,861 Views)
Accepted by Nemesis
Dear Alex,
Thank you for interested in my topic. I have just figured out how to do it. I went through this example: https://www.ni.com/en/support/documentation/supplemental/06/linear-waveform-generation-with-compactr.... However I modyfied a bit FPGA interpolation method. The one that is described does nove me smooth enough movement. I attached files if somebody will need one day. I think the case is closed.
(4,854 Views)
