Is it possible to boot cRIO from the USB drive?
A customer tells me that it is possible to set up cRIO-9014 to boot from a USB memory stick instead of the internal flash memory...is this true and if so how is it done? I can see the possibility of specifying a different directory for the startup app, but is that all - or can you load the whole OS from the u-drive as well?
(4,245 Views)
Not sure if it's possible but I believe this is what your customer was referring to:
Reference Design for Deploying CompactRIO Application Updates using a USB Memory Device
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,241 Views)
Thanks.
The goal is to be able to fix problems with the unit by replacing the USB memory stick though, so there is no app running that can do the reload.
(4,236 Views)
Currently it is not possible to boot a cRIO-9014 controller directly from a USB memory device. This feature has been requested multiple times and is something we are researching.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(4,203 Views)
