how to export signal from signalexpress to matlab real time?
i'm currently working on my graduating project and i'm using Labview Signalexpress 2009. I'm measuring with a pneumotachograph using a NI CB-68LPR card. I've filtered the signal and it's looking good right now. Now my question is, how do i get this signal (or data) realtime into matlab or another program?
(goal is to let a ball move on the value of the signal. So higher voltage means higher speed of the ball. Therefore everything must be processed in realtime.)
Greetings,
Eriktw
(3,715 Views)
You won't be able to do that through LabVIEW SignalExpress except if you are planning to save that signal data in a file and then read the file from Matlab. You could use LabVIEW to do the same or use a communication protocol that both applications support.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,707 Views)
Hello Erik,
please start only one discussion about the same topic .
Martijn S
NI Netherlands
(3,699 Views)
