JESD204b interface with PXIe-7975
I would like to setup a JESD204b interface using a PXIe-7975. I can't see anything in the literature about it so it may not be possible. However, if anybody can confirm this I can then move onto considering a different solution.
(3,444 Views)
Accepted by Aamir_mesuro
I found this example code. I hope it helps you.
JESD204B Simple Streaming Example for the PXIe-6591R High-Speed Serial Instrument
Certified LabVIEW Developer
GCentral
(3,414 Views)
Thank you for the suggestion. I will look into this in more detail
(3,411 Views)
The PXIe-7975 is an FPGA back end. It is only capable of interfacing with modular FlexRIO Adapter Modules.
https://www.ni.com/en/shop/electronic-test-instrumentation/flexrio/what-is-flexrio/components-of-a-f...
Since none of the modular FlexRIO Adapter Modules provide a High Speed Serial interface that can be used for JESD communication you won't be able to use your PXIe-7975 as part of a JESD link.
https://www.ni.com/en/shop/electronic-test-instrumentation/digital-instruments/what-is-pxi-high-spee...
The PXIe-6591 is a High Speed Serial device you'll want to take a look at since it has a published JESD204b example that Emboar has already linked to.
(3,400 Views)
