10-05-2018 08:49 AM
I would like to setup a JESD204b interface using a PXIe-7975. I can't see anything in the literature about it so it may not be possible. However, if anybody can confirm this I can then move onto considering a different solution.
Solved! Go to Solution.
10-11-2018 02:25 AM
I found this example code. I hope it helps you.
JESD204B Simple Streaming Example for the PXIe-6591R High-Speed Serial Instrument
10-11-2018 03:50 AM
Thank you for the suggestion. I will look into this in more detail
10-11-2018
12:13 PM
- last edited on
12-17-2024
03:38 PM
by
Content Cleaner
The PXIe-7975 is an FPGA back end. It is only capable of interfacing with modular FlexRIO Adapter Modules.
Since none of the modular FlexRIO Adapter Modules provide a High Speed Serial interface that can be used for JESD communication you won't be able to use your PXIe-7975 as part of a JESD link.
The PXIe-6591 is a High Speed Serial device you'll want to take a look at since it has a published JESD204b example that Emboar has already linked to.
