08-15-2012 04:17 PM
Do you know if the compile worker is running? Can you manually start it?
To manually start the compile worker, go to Start>>Programs>>National Instruments>>FPGA>>FPGA Compile Worker. You should then see the compile worker running in your Notification area in the bottom right of your screen.
Best,
09-17-2012
08:55 PM
- last edited on
10-28-2025
01:10 PM
by
Content Cleaner
Something isn't right. I do not get any data terminals if try and manually select a 9870 port from an FPGA I/O method. See this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z00000159p7SAA&l=en-US
Where are the data terminals???
09-18-2012 11:37 AM
Hi Acquisition,
Are you sure you selected ModX/PortX? If you just select ModX, it will not work. Please show a screen shot of the behavior if this doesn't help.
Best,
09-18-2012 12:19 PM
See below image. If I select Mod1/Port4, then click the method to select "Read Byte", I do not get a Data, Timeout (ms), or Timed Out terminals.
It should look like this:
Any ideas? This occurs in Labview 2012. Labview 2011 seems to work without issue. I have attached the above Labview 2012 project. Does this issue occur in Labview 2012 for anyone else?
09-19-2012 04:55 PM - edited 09-19-2012 05:01 PM
Hi Acquisition,
This was reported to R&D (#370152) for further investigation. One thing you could try is using an example for the NI 9870 from the NI Example Finder to give you a starting place.
Thanks for the feedback!
09-19-2012 05:10 PM
Jeff - Thanks for the response. I was able to get around the issue by placing all the required methods in Labview 2011, then opening in 2012. If I did not have 2011 installed I would have been out of luck.
