LV for cRIO
Do you know if the compile worker is running?  Can you manually start it?
To manually start the compile worker, go to Start>>Programs>>National Instruments>>FPGA>>FPGA Compile Worker.  You should then see the compile worker running in your Notification area in the bottom right of your screen.
Best,
Jeff S.
Message 11 of 16
(3,103 Views)
Something isn't right. I do not get any data terminals if try and manually select a 9870 port from an FPGA I/O method. See this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z00000159p7SAA&l=en-US
Where are the data terminals???
Message 12 of 16
(3,078 Views)
Hi Acquisition,
Are you sure you selected ModX/PortX?  If you just select ModX, it will not work.  Please show a screen shot of the behavior if this doesn't help.
Best,
Jeff S.
Message 13 of 16
(3,065 Views)
See below image. If I select Mod1/Port4, then click the method to select "Read Byte", I do not get a Data, Timeout (ms), or Timed Out terminals.
It should look like this:
Any ideas? This occurs in Labview 2012. Labview 2011 seems to work without issue. I have attached the above Labview 2012 project. Does this issue occur in Labview 2012 for anyone else?
Message 14 of 16
(3,060 Views)
Hi Acquisition,
This was reported to R&D (#370152) for further investigation.  One thing you could try is using an example for the NI 9870 from the NI Example Finder to give you a starting place.
Thanks for the feedback!
Jeff S.
Message 15 of 16
(3,035 Views)
Jeff - Thanks for the response. I was able to get around the issue by placing all the required methods in Labview 2011, then opening in 2012. If I did not have 2011 installed I would have been out of luck.
Message 16 of 16
(3,029 Views)
