Load a linux shared library into the CompactRIO automatically.
Hello!
I'm trying to create a package to use with the CompactRIO (Linux RT). This package has some vi's that call a linux shared library located in my project folder (Windows system).
When I manually copy the .so file into the CRIO, everything works fine.
The problem is that I need to copy or deploy this .so automatically, in other words, I want to install my Package and make it copy the .so file into the CRIO automatically.
How can I do this? Can anyone help me?
Thank you in advance!
(3,059 Views)
Do you want to deploy your application into many CompactRIO?
As far as I remember, RAD Utility duplicate not only your application but also required library.
Please try it out : )
Certified LabVIEW Developer
GCentral
(3,034 Views)
Yes, the idea is be able to install this package using VI Package Manager (in Windows or even Linux environment) and use it in any CRIO. It will works like a LabVIEW library, where I can create a project and run it in CRIO.
Thank you! I'll take a look!
(3,028 Views)
It's not what I'm looking for... 😕  If anyone have any other idea, would be great!
Thank you!
(2,979 Views)
