UDP Multicast Fails on Linux RIO Device with a Static IP
I'm in the situation described by the KB UDP Multicast Fails on Linux RIO Device with a Static IP.
It says that 2 files have to be modified : add the rule below to the network interface configuration files in /etc/ifplugd/ifplugd.actions and in /etc/natinst/networking/ifplugd.script.
However, etc/ifplugd/ifplugd.actions is a symbolic link that point onto /etc/natinst/networking/ifplugd.script file... So does this mean that in reality only one file has to be modified ?
Or the only other file within /etc/ifplugd folder, which is ifpludg.conf, is the one to be modified also ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,548 Views)
CyGa,
What's the model of your cRIO?. Welcome to the minefield of cRIO OS deployment of NI, I wish they would commit to 100% uniformity of performance across the OS's.
(2,535 Views)
It's a 9049.
I applied the fix on the only file I could find and restarted the cRIO : unable to recognize it anymore! I guess I'm good for a factory reset...
(2,533 Views)
