Lost connection on cRIO9022
I have a hard time with my cRIO9022. I'm tring to do a monitoring/control system using a 9211, 9870, 9208.
Basicly, I use the 9211 for monitoring 4 themocouple, use the 9208 for 10 pressure sensor (4 to 20 mA), 9870 for RS232 control
When I debugging my software developpement, if I stop the code using the "Abort Execution" once, I can make some modification and restart without problem. But, if I do it twice, I lost the communication, I can't reconnect to the NI-cRIO inside the LabView Developpement Project, but still answer to ping from my computer. WebServer don't work at this time. I need to go back to the lab and reset the controllor.
Do you have a workaround for that?
Thank
(5,370 Views)
CFiset,
Avoid using the "Abort Execution".   Front panel of Host.vi for cRIO should include a "Stop Execution" button that stops Host.vi in a controlled and predictable manner.
(5,366 Views)
