Low power motherboard for Labview Real-Time
I am looking for a low power platform for Labview Real-Time. I have done a lot of searching, but so far it has been very difficult finding low power motherboards with more than three PCI-slots.
I need the motherboard for control of prototype systems, and the system needs to run on 24 V DC (I already found a nice power supply on www.mini-box.com that will take anything between 8 and 30 Volts). As the system has to run on 24 VDC, the power requirements of the system is rather important, and I would like to keep it below 30 Watts.
I found and bought a very promising motherboard from Kontron, but unfortunately it seems that the motherboard isn’t capable of running Labview RT:
http://www.kontron-emea.com/index.php?id=226&cat=64&productid=489
No matter what I do, I get an error message saying that Labview is unable to configure the primary network controller, which sounds a lot like the error message mentioned under additional requirements in the official document on supported PC hardware:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/cb3434da94466dd286256e9e006bb775?OpenDocument
I would like to know if anyone have some experience with using the Celeron or Pentium m processors for Labview Real-Time, and especially if anyone have found a working motherboard with four or more PCI-slots.
Any help would be greatly appreciated.
Message 1 of 18
(8,812 Views)
It seems that LV Real-Ttime Tragets dosen't support the 3xGbE LAN on the motherboard from Kontron(I can't see which chipset it has).
You can always get one PCI-ethernet instead with supported chipset, and still have 5 PCI-slots left.
Supported Ethernet Chipsets: A network adapter with a supported ethernet chipset is required. The adapter can be integrated to the motherboard or PCI.
  • NI-PCI-8232 GPIB/Gigabit Ethernet
  • Intel® 82540
  • Intel® 82559
  • Intel® 82558
  • Intel® 82550
  • Broadcom® 5751
    An example of a board that carries the Intel® 82540 chipset is the NI-PCI-8232 GPIB/Gigabit Ethernet.
    An example of a commercially available board that carries the 82550 chipset is the Intel Pro/100 S.
Regards
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
Message 2 of 18
(8,792 Views)
Hi Morini
Thank you for your answer.
Unfortunately I forgot to mention that I already tried the Intel Pro/100S, and Labview still can't detect it. I actually tried two different ethernet adapters, just in case one of them should be out of order.
BTW - the onboard LAN is Realtek, so it is definately not supported.
Message 3 of 18
(8,787 Views)
Have you disabled the onboard networkcard and USB support from the Bios?
Regards
Dennis Morini
Message 4 of 18
(8,784 Views)
Yes, I have tried disabling both onboard LAN,  USB and serial and parallel ports.
Message 5 of 18
(8,778 Views)
Well, if you have followed the steps mentioned in http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/cb3434da94466dd286256e9e006bb775?OpenDocument and it still doesn't work, then it seems that we have a hardware compatiblity issue here.
Maybe you have to choose another motherboard to work with, however if you still want to use the Kontron motherboard, I can escalate your problem to our specialists and they will have a look at this problem.
Regards
Dennis Morini
Message 6 of 18
(8,780 Views)
I did follow all the steps mentioned in that document, so I am afraid it might be a hardware compatibility issue (actually as I already mentioned, it might be the issue listed under Additional requirements in the document). I would be most thankfull if you would pass the issue on to your experts, as I haven't been able to find a low power motherboard with as many PCI slots.
If I could only find a similar motherboard I wouldn't mind using that either.
Message 7 of 18
(8,773 Views)
Hi, your question has been escalated.
There is one more thing, which processor are you using on the Kontron motherboard?
Regards
Dennis Morini
Message 8 of 18
(8,763 Views)
You might consider
This is a very good candidate
– it is in mini-ITX format (about 7" x 7"), low-power, has one standard PCI slot, and Intel 82551 Ethernet chipset: http://www.ampro.com/html/MightyBoard_800.html
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
Message 9 of 18
(8,752 Views)
I am using a pentium m, 1.8 GHz, 478 µFC-PGA, from Intels embedded processor line.
@Preston: thanks for the suggestion, but unfortunately I can't do with just one PCI slot, as I need at least three for my data acquisition cards plus one for the ethernet card. It is very nice that it has the right ethernet chipset onboard though - if only it had two more PCI slots it would be perfect.
Message 10 of 18
(8,743 Views)
