04-11-2006
07:17 AM
- last edited on
04-21-2025
10:06 AM
by
Content Cleaner
I am looking for a low power platform for Labview Real-Time. I have done a lot of searching, but so far it has been very difficult finding low power motherboards with more than three PCI-slots.
I need the motherboard for control of prototype systems, and the system needs to run on 24 V DC (I already found a nice power supply on www.mini-box.com that will take anything between 8 and 30 Volts). As the system has to run on 24 VDC, the power requirements of the system is rather important, and I would like to keep it below 30 Watts.
I found and bought a very promising motherboard from Kontron, but unfortunately it seems that the motherboard isn’t capable of running Labview RT:
http://www.kontron-emea.com/index.php?id=226&cat=64&productid=489
No matter what I do, I get an error message saying that Labview is unable to configure the primary network controller, which sounds a lot like the error message mentioned under additional requirements in the official document on supported PC hardware:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/cb3434da94466dd286256e9e006bb775?OpenDocument
I would like to know if anyone have some experience with using the Celeron or Pentium m processors for Labview Real-Time, and especially if anyone have found a working motherboard with four or more PCI-slots.
Any help would be greatly appreciated.
04-12-2006
02:37 AM
- last edited on
04-21-2025
10:07 AM
by
Content Cleaner
It seems that LV Real-Ttime Tragets dosen't support the 3xGbE LAN on the motherboard from Kontron(I can't see which chipset it has).
You can always get one PCI-ethernet instead with supported chipset, and still have 5 PCI-slots left.
Supported Ethernet Chipsets: A network adapter with a supported ethernet chipset is required. The adapter can be integrated to the motherboard or PCI.
Regards
04-12-2006 02:53 AM
04-12-2006 05:33 AM
Have you disabled the onboard networkcard and USB support from the Bios?
Regards
04-12-2006 06:47 AM
04-12-2006
07:42 AM
- last edited on
04-21-2025
10:07 AM
by
Content Cleaner
Well, if you have followed the steps mentioned in http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/cb3434da94466dd286256e9e006bb775?OpenDocument and it still doesn't work, then it seems that we have a hardware compatiblity issue here.
Maybe you have to choose another motherboard to work with, however if you still want to use the Kontron motherboard, I can escalate your problem to our specialists and they will have a look at this problem.
Regards
04-12-2006 07:56 AM
04-12-2006 08:34 AM
Hi, your question has been escalated.
There is one more thing, which processor are you using on the Kontron motherboard?
Regards
04-12-2006 02:36 PM
You might consider
This is a very good candidate
– it is in mini-ITX format (about 7" x 7"), low-power, has one standard PCI slot, and Intel 82551 Ethernet chipset: http://www.ampro.com/html/MightyBoard_800.html
04-13-2006 03:31 AM
I am using a pentium m, 1.8 GHz, 478 µFC-PGA, from Intels embedded processor line.
@Preston: thanks for the suggestion, but unfortunately I can't do with just one PCI slot, as I need at least three for my data acquisition cards plus one for the ethernet card. It is very nice that it has the right ethernet chipset onboard though - if only it had two more PCI slots it would be perfect.
