MAX
Hello Autonomous,
not really because it dependencies. You can upgrade to
NI System Configuration 5.3.3
but i think the problem is the network connections.
Can you send a ping to the rio?
best regards
Alexander
Message 11 of 26
(3,734 Views)
Hello Alexander,
How am i supposed to send a ping on it, when the program can  not  run?
cheers,
Samira
Message 12 of 26
(3,725 Views)
Hello Alexander,
Now MAX knows the device but IP addresses on MAX & LV project do not match(as attached) should i write it manually on MAX?
Samira
Message 13 of 26
(3,721 Views)
Message 14 of 26
(3,719 Views)
THAT PROBLEM IS SOLVED! but i can't delete the last 2 msges  😄
Thank u for answes till now
Message 15 of 26
(3,712 Views)
Hello AutonomousMode,
no problem, normally we use the ip adress from the MAX and set this in the LabVIEW
project explorer under properties general to the cRIO, to connect them.
best regards
Alexander
Message 16 of 26
(3,705 Views)
Dear Alexander,
Thanks and best regards,
Samira
Message 17 of 26
(3,702 Views)
Hello Alexander!
  i'm trying to read the data from a laser scanner using the ACT/LINK port(sick LMS100),but i don't exactly know how to read data. What kind of file is the output?  a text/graghic file? Do u know an example that could help?i attached the simplest example, but about Sick, i found nothing so useful in datasheets. Can u plz refer me to some useful docs?
Message 18 of 26
(3,687 Views)
here you can find the discription of the using from the Telegrams LMS 100.
We do not have an example for it, but you can try to contact this
persons from VolksBot Lab they should have one.
best regards
Alexander
Message 19 of 26
(3,685 Views)
Hello Alexander,
Thanks and best regards for the valuable data.
Samira
Message 20 of 26
(3,678 Views)
