MTBF on cRIO components
Folks,
I need MTBF data on the following cRIO components:
cRIO-9073
cRIO-9476
cRIO-9425
cRIO-9421
cRIO-9401
cRIO-9219
cRIO-9263
cRIO-9871
Thank you for your help.
Blaine
(6,601 Views)
Hi Blaine,
The following MTBF numbers are all at 25°C with the Bellcore Issue Level II method.  These values can be found in the Operating Instructions and Specifications Manuals for each respective module.
9476 - 1,091,425 hours
9425 - 1,256,699 hours
9421 - 2,086,204 hours
9401 - 1,244,763 hours
9219 - 384,716 hours
9263 - 1,732,619 hours
9871 - 514,016 hours
The cRIO 9073 did not list this in the manual, so I will have to get back to you with that answer.
(6,585 Views)
Chris,
Thanks for leading me to the water.  Sorry I missed that info.  Just post when you get the 9073 info.
Blaine
(6,583 Views)
Hi Blaine,
Because the cRIO-9073 MTBF is not published in the manual I will have to request that you contact your local FSE, or create a SR to request this information from R&D.  If you need help determining your local FSE, use this link.
(6,566 Views)
