03-05-2013 04:29 PM
Folks,
I need MTBF data on the following cRIO components:
| cRIO-9073 |
| cRIO-9476 |
| cRIO-9425 |
| cRIO-9421 |
| cRIO-9401 |
| cRIO-9219 |
| cRIO-9263 |
| cRIO-9871 |
Thank you for your help.
Blaine
03-06-2013 04:27 PM
Hi Blaine,
The following MTBF numbers are all at 25°C with the Bellcore Issue Level II method. These values can be found in the Operating Instructions and Specifications Manuals for each respective module.
9476 - 1,091,425 hours
9425 - 1,256,699 hours
9421 - 2,086,204 hours
9401 - 1,244,763 hours
9219 - 384,716 hours
9263 - 1,732,619 hours
9871 - 514,016 hours
The cRIO 9073 did not list this in the manual, so I will have to get back to you with that answer.
03-06-2013 04:29 PM
Chris,
Thanks for leading me to the water. Sorry I missed that info. Just post when you get the 9073 info.
Blaine
03-07-2013 05:42 PM
Hi Blaine,
Because the cRIO-9073 MTBF is not published in the manual I will have to request that you contact your local FSE, or create a SR to request this information from R&D. If you need help determining your local FSE, use this link.
