The integers represent ticks of the clock used by the counter and will be dependent on the specific parameters and hardware used. The two default clocks on most boards are 100 kHz and 20 MHz. So in the case of the 20 MHz clock, divide the integers by 20e6 and this will give you the time in seconds.
Christian L
NI Consulting Services
authored byChristian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
