Modbus Slave server stop functions if have request frame with address 0 (broadca
There is no errors in VIs!!! Problem is ModbusSlave!!!. Please look ModbusSlave
Message 11 of 12
(1,303 Views)
Hi alexart,
There are two ways to do what you are trying to do with your MODBUS slave. You can see in this KnowlegeBase article that the two options are to use the DSC Module, or to make use of the MODBUS library.
It seems that you are attempting to recreate the functionality of the MODBUS library, which is going to be much more trouble that it is worth, since the library can be downloaded for free from the link above.
Stephen S.
Applications Engineering
Message 12 of 12
(1,271 Views)
