Module 9205
What is sample rate of ni 9205 per channal.
What is the minimum timing I can acquire by using compactRio fpga mode ?
(1,175 Views)
9205 can sample up to 250kS/s aggregate. This means, that when only 1 channel is active you can achieve 250kS/s, when 2 channels are active, you can achieve 125kS/s ... when all 32 single-ended channels are used you can get 7.8125kS/s
Regarding sampling rate in cRIO FPGA,
To know more about aggregate sampling rate, read - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIz9SAE&l=en-US
Santhosh
Soliton Technologies
(1,159 Views)
Thank you.
Where can I select the channels I want to activate?
(1,113 Views)
