Multi Acquisition
I am  working with  PCI-6601 from 4 channels: I try to generate two signals them and to acquire of a third signal (moreover trigger with one of the two signals generates them to you), but  a problem has been placed : it gives always an error to me of the type “The specified resource is reserved”. Considering that I am using of the examples base which Count Digitl Events… and Gen Digit Pulse-Finite.vi moreover.  Initially when I had only one signal them of generation in contemporary to one of acqusizione, if I put the first one on ctr0 and the second ctr1, there was also in this case the error, then the thing has been  resolved placing on the second ctr2 (goodness knows because then…). Now, because I have one signal  in more, there is this error another time  to me (you hold account that I have controlled every turns the just connections on the pin…).  Some idea or suggestion?  Thanks
Message 1 of 1
(3,357 Views)
