NI 9870 Serial Port Communication
I have the 9870 rs232 serial module on a cRIO 9073 chassis. I have looked at the serial loopback example, added to my project, changed the input node to point to the right serial port. This works fine when I use a loopback connected to the serial port cable.
However, when I connect the port to the serial port at the back of my pc (using female to female serial cable) and run the 'Serial Loopback DMA Rd (Host).vi' I cannot see any data sent on hyperterminal monitoring the com port of my PC. Also if I type any characters on hyper terminal I cannot see them being received by the LabView program.
Why is this happening? i.e. the example working well with a loopback adapter and not when connected to another serial port?
All help will be appreciated.
regards
Harshil
(7,380 Views)
Accepted by hkhiroya
Do you have any details on the cable you are using? You may need a null modem cable.
Do all the settings in hyperterminal match the cRIO? I.E: Baud rate/parity/start and stop bits etc
Could you take a screenshot of the hyperterminal settings and also the windows serial port settings? Could you attach your cRIO VI?
Many Thanks,
(7,366 Views)
I have checked, and all my settings match the ones on the cRIO.
The cable I am using is standard (female to female) cable. I have given the link for it below.
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=215-426&...
I will try and use a null modem cable.
Also, I have attached the screenshots as requested.
Thanks for the help.
 Harshil.
(7,358 Views)
Attached is the windows port setting.
(7,354 Views)
Thanks for the help. Null modem cable did the job.
Regards
Harshil.
(7,305 Views)
Hello Mark,
I have connected NI 9870 on cRIO 9073.
Chroma power supply is connected to port 2 of NI 9870.
I am trying to communicate with it using DMA FIFOs.
I am able to send/write command to it like switching power supply replay ON and OFF.
But when I try to read from command *IDN?\n  I get blank response.(only spaces)  Smiley Sad
do you have any idea what could be missing?
Any help is appreciated.
Thanks.
Dev
CLD Certified Engineer
(6,564 Views)
Hey Harshil,
I am trying to use the similar program, i guess its not working for me. I just want to write a string to the serial port. I have the example setup, no errors, but output either on computer or scope.
Can you please post the exmaple and also you talked about the loopback adapter, what is that? I think i may be missing some thing here.
I will greatly appreciate that.
Ajay
(5,789 Views)
