NI 9870 on 9144 using EtherCAT: not supported?
Correct, this is the French version of Labview. Do you have a workaround? Otherwise I can call the French support team but many people are taking a day off tomorrow in France. 🙂
Message 11 of 15
(3,954 Views)
It is just a hunch that the problem is a localization issue, try changing your operating system to English and using the English version of LabVIEW. If that fixes the problem I can file a bug report immediately.
Jesse Dennis
Engineer
INTP
Message 12 of 15
(3,950 Views)
You can't "change the operating system to English" anymore. 🙂 but I can install a natively English Windows I guess, and install the English copy of Labview I'm downloading right now. I will let you know if it works asap.
Thanks again.
DLB
Message 13 of 15
(3,947 Views)
Searching, I found this link
http://digital.ni.com/public.nsf/allkb/A1DEA3B97FEE3A1086257A8D005898D7?OpenDocument
This looks like an answer to my problem. Too bad it didn't match my first issue, I totally forgot about it after...
Thank you for everyone's help, I'll close the issue when I can confirm it's the right fix.
DLB
Message 14 of 15
(3,943 Views)
Accepted by topic author Proengin
Fix confirmed.
DLB
Message 15 of 15
(3,935 Views)
