 viScience
			viScience
			05-19-2009 04:02 PM
I have a PXI 6682 with NI-Sync 3.1 and have verified a good GPS IEEE1588 master clock on the PC.
I have loaded the NI-SYNC Pioneer on my cRIO but cannot see any sort of time sync. Also
a IEEE1588 property called clock state is reading 'faulty'. The only evidence that anything has changed on my
cRIO is that now timed loops are not syncing to the scan engine. I had to change scan sync'd timed loops to fixed
iteration times to get my rt app running again. Has anyone had any luck with the NI-SYNC pioneer software?
05-19-2009 08:58 PM
05-19-2009 09:56 PM
I have two cRIO-9074 chassis each with a 9144 EtherCat expansion chassis.
05-20-2009 04:43 PM
Is your system using a Link-local IP? If so, the Beta 2 of the SW Sync pioneer will support waiting for the IP to come up before going faulty (Link Local IP may take up to 60 seconds). Note that Beta 2 of the SW Sync which isn't up on the web yet (though we could provide it to you) only supports the LabVIEW 2009 platform beta.
