NI Veristand Deploy to Target Issues
Hello everyone,
For a while now I'm facing a particular problem I can't seem to solve. It happens when I want to deploy my Custom Device(Inline Model Interface) to the target, and during deployment I get this message:
• Start Date: 10.10.2019 7:40
• Loading System Definition file: C:\Users\Public\Documents\National Instruments\NI VeriStand 2017\Projects\Empty Project\Empty Project.nivssdf
• Preparing to deploy the System Definition to the targets...
• Compiling the System Definition file...
• Starting VeriStand PC Engines...
• Initializing TCP subsystem...
• Starting TCP Loops...
• Connection established with target Controller.
• Sending reset command to all targets...
• Preparing to deploy files to the targets...
• Starting deployment group 1...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -307662 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
NI VeriStand: Node is not found in the system.
NI VeriStand: NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> NI VeriStand Engine.lvlib:Initialize Inline Custom Devices.vi >> Custom Devices Storage.lvlib:Initialize Device (Model Interface).vi
• Shutting down VeriStand PC Engines...
• Stopping TCP loops.
Waiting for TCP loops to shut down...
• TCP loops shut down successfully.
• Unloading System Definition file...
• Connection with target Controller has been lost.
This problem started occuring after an RT Driver VI.vi file got "corrupted" and I had to redo it from template again. The whole project was then rebuilt from scratch, but the error prevails.
Other Custom Devices from a different project are deployable.
If any additional information is necessary, I'll provide it of course
Any sort of help or direction where to look for solution would be appreciated
Marek
Message 1 of 1
(2,437 Views)
