NI Veristand and cRIO-9068
A simple question : Does NI Veristand run on a cRIO-9068 controller.
Thanks for the answer.
(6,872 Views)
Hi Bob
Thanks for asking your question on NI's Forum !
Unfortunately, Veristand is not supported on the 9068 (using Zync architecture and LinuxRT OS).
You will see that it is not possible to install Veristand Engine on this target from NI MAX, as it is possible with other cRIO.
Vincent
(6,844 Views)
Unfortunately, I just bought crio 9068 and planned to run with veristand. Is there any possibilities?
(6,472 Views)
VeriStand is supported on many of the VxWorks based controllers.  Your best option is to find your local NI sales engineer and see if it is possible to exchange the cRIO-9068 for a different cRIO model.  The operating system support is different enough that you will not be able to get VeriStand to run on the 9068.
(6,367 Views)
