making sbrio standalone
I am working on a project in sbrio 9462.
I am unable to work the sbrio standalone. how do i do that?
i can configure the ports and all using the real time project!! but i dunoo how to make the sbrio standalone. anybody please help.
(4,626 Views)
Well you just need to install the executable on the sbRIO. Have you created an executable before? Let us know.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,619 Views)
Yes i have made a project using the real time project wizard its working with the ethernet cable connected. I just need to know how i can blink an led stand alone! i want it urgent because of one deadline coming up . Thank you!
(4,616 Views)
You didn't answer my question. You will need to create an executable and then you can configure it to run at startup. Have you followed these steps:
Building a Stand-Alone Real-Time Application (RT Module)
Running a Stand-Alone Real-Time Application (RT Module)
Adnan Zafar
(4,614 Views)
Hi.... I have a doubt for example I have a microphone conected to sbrio 9631 by a NI 9234 but the problem is that I have to use the NI sound and vibration to acquire Db(A) of the noise. I would like to know if I can use the NI sound and vibration to create a stand-alone aplication to measure the db(A) with the microphone 40 p.h. because when I am developing an aplicaion en the FPGA I can´t use the toolkit NI sound and vibration.
(3,749 Views)
