NI WSN not installable on cRIO 9068
Hi Gents/Ladies
We have a NI 9795 WSN c-series module that we wanted to use with the cRIO-9068 controller.
We found, however, that we could not install NI-WSN 1.5 onto the real time target - it did not appear as one of the drivers that could be installed in MAX.
I installed NI-WSN 1.5 onto a 9075 and a 9012 that we have in the office - no problems.
So we need to know whether NI-WSN 1.5 is installable (mormally) on the 9068.
If it cannot, can you please provide reasons?
If so, please tell us what you need from us to assist you with troubleshooting the problem.
(5,335 Views)
 Hi DenverRod,
Currently, the 9795 WSN C-series module is not compatiable with the cRIO-9068 Controller and that is why you are running into this issue.
Any other CompactRIO that is not Linux based will work with the 9795 module that you currently have. For more information, you can go to this cRIO Software Versions page.
Douglas Choisnet
(5,310 Views)
Ok. Noted.
Thanks Douglas C.
(5,308 Views)
