Problems with creating Testbench for FlexRIO
Hi all,
I have tried to create a testbench for a VI running on a flexRio PXI-7952R board. I followed the tutorial in the Labview help, but I cannot make it run.
Everything works fine when I simulate for a R-Series (e.g. PCIe-7852R) board. But when I use a FlexRio-Board I get the following error message:
Fehler -61399 ist bei Execution of an FPGA VI on the development computer aufgetreten
Mögliche Ursachen:
LabVIEW FPGA:  Die Ausführung des FPGA-VIs auf dem Entwicklungscomputer wird für das Objekt bzw. den Knoten im benutzerdefinierten VI für die FPGA-I/O nicht unterstützt.
Node type: Read I/O
I/O item:  IO Module\SPI Busy
(Sorry for the German)
I am sure that I have created cases for all IOs.
I think, the Problem is, that in the Testbench-VI the name of the IO-Case is expected to be "IO Module\*IO_Name*" and not simply "*IO_Name*" as it is the case for the R-Series devices. The problem is that the backslash is not accepted in the case name but simply deleted for the string.
Does anybody know a workaround for that issue?
Matthias
(4,057 Views)
Hi Matthias
Please have a look at this forums post and this KB:
FPGA simulated I/O Recive error -61399,
Error -61399 When Execute FPGA VI on Development Computer With Custom VI for FPGA I/O
Kind regards
Pixar
(4,035 Views)
I just wanted to add that the "\" character is generally used to indicate a special character.  To enter a literal backslash  "\" in the case structure, use a double backslash "\\".  This should help with the "IO Module\..."  items in your VI.
(3,960 Views)
I apologize for resurecting an old post but ran into error -61399 with NI 6581 +PXIe-7966R.
My input is DIO1, output is DIO6. I can compile by using the workaround suggested by Jennifer O. e.g. IO Module\\DDCA_DIO6_Write
Mohit Kapur
(3,430 Views)
