NI-XNET: (Hex 0xBFF6308A) The interface name given does not specify a valid and existing interface. Solution: Use a valid and existing interface.
I am using PXIe-8880 with a CAN module like PXIe-8510. When I use the demo“can loopback test.vi” from the example finder, for the input Interface, it does not let me select my CAN interface (e.g. CAN1, CAN2). It is fixed name(e.g. CAN1 or CAN2,). When I work with this vi, I get an error:(all the demo with the same problem) “NI-XNET: (Hex 0xBFF6308A) The interface name given does not specify a valid and existing interface. Solution: Use a valid and existing interface. These can be obtained using MAX, XNET system properties, or the LabVIEW XNET Interface IO name. If you are using CompactRIO, refer to the topic "Getting Started with CompactRIO" in the NI-XNET Hardware and Software Help.”
(3,692 Views)
Are you using PXIe-8880 as a Windows target or Real-Time? If it is Real-Time, do you have NI-XNET installed in PXIe-8880?
(3,670 Views)
use PXIe-8880 as a Real-Time, I have NI-XNET installed in PXIe-8880。
(3,661 Views)
