NPSV problem
Hello everyone,
I am having a problem, and I would really use any advice.
I have created two VIs: Master (on my PC) and Slave (on my cRIO). On cRIO I have assembled DO module, and cRIO is programmed for scan interface mode, and my DO channel is under chassis, as I/O variable. I have also created a NPSV within cRIO, in order to transfer change of control button to Slave vi.
I have created a control button, since I wanted to control DO channel. I have connected that control with NPSV (master VI, my PC). And in Slave vi (on cRIO) I have connected this variable with I/O variable for that digital output channel.
It did not work if I run only master vi. When I was running master and slave vi, it worked, and the led was on.
I still dont know how to explain that, and I would really really use your help.
Another thing, when I connect just a control button with I/O variable, in my master vi, without changing anything in slave, the led is on. It is one thing which I also dont understand. If I didnt change anything in slave, how does master vi communicates with the module.
Thank you for your help.
(2,454 Views)
I can pinpoint your problem to one thing:
@User002 wrote:
created a NPSV
NPSVs have just been a nightmare for me.  They are meant to be simple, but they introduce all kinds of weird race conditions and other weird behavior like what you are describing.  I actually deem NPSVs to be evil.
Instead, use a simple TCP/IP connection to send the updates/data back and forth.  Network Streams are another option.
(2,406 Views)
