NSV w/ RT-FIFO has strange behavior
After enabling RT-FIFO (single element) on a cRIO hosted NSV my previously working application is failing to read the correct value of this NSV.
I can see and verify the NSV value using the DSM but within my labview exe it does not read it correctly (it is a boolean value and always returns False even when it is True)
Another strange aspect to this is that the same LabVIEW exe runs fine when executed as a vi within the development environment.  I have a conflicting mix of  information regarding whether or not
NSV w/RT-FIFO create separate client side buffers for multiple readers.  This is stated to be the case in the famous SV white paper from NI but elsewhere in the discussion forums I have heard that
it actually does not work that way.  In any event, I still do not understand why this would cause the problem I am seeing.  Once again, shot in the foot with NSV's due to inconsistant behavior and/or incorrect documentation.
(3,267 Views)
Is the EXE that is causing this bad behavior running on Windows or on the cRIO target?
I tried reproducing this behavior in a simple example and could not see the same effect. Can you put together a simplified example that shows the behavior that you can share with us?
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,249 Views)
Hi Christian,
Thanks for looking into this.  The exe I was refering to was running on Windows with the NSV's hosted on the cRIO.
Perhaps I am expecting too much from the PSP to keep all my various readers updated with the latest NSV value.
My cRIO readers are using the SV API and I verified that they are working but on the windows side I am using tags
which do not update correctly.  I will see if I can find some time to revisit this and put together an example...for the moment I have disabled the RT-FIFO
option.
(3,245 Views)
