real time application using usb 6009
Hy, i'm having a probleme graphing in real time. I'm using a gyroscope and an usb 6009, i manage to calculate the angle. But now i want to show on a graph  while moving the gyro at the same time to show me the angle in another graph.
Fana
(3,271 Views)
How exactly have you designed the application? Posting an example would make it easy for us to visualize the issue. Also, it's best to not have any user interface on the real time application itself. You should always communicate from a host VI to the real time application, and have all user interface take place on the host application.
Real-Time VI to Host VI Communication Methods
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,263 Views)
Hy,
I dont't know for sure if it's a real-time application. i will describe what i want to do, and then attach the vi to see where my problem is.
I have an usb 6009 and  one axis gyroscope . When i'm rotating the device, i want to plot on a graph only the angle of movement. For exemple, if i'm rotating 30 degree, to apear a line at 30 for example, and so on. Can you give a reply with your email addres? to send there more information.
Thank you,
Fana
(3,261 Views)
