Need solution for measuring weight in grams for Automation
I have requirement of measuring weight of empty vessel ( in grams) at start & weighing it after some liquid is present ( 4- 5 grams). So it should detect 4 - 5 grams change. I have to use this value in my TestStand script & do some analysis on it.
We are doing it manually now So for automation I wanted to know which device I Can use for this weighing activity.
Your suggestion & Idea will really help me ! Thanks in advance !!
(2,288 Views)
My suggestion is using a balance product which has USB or any other interface.
For example, ADC corp provide so many type of the product.
Search by Capacity and Resolution
Then, communicate with LabVIEW via USB.
Certified LabVIEW Developer
GCentral
(2,263 Views)
