PCI base DAQ interfacing
Sir i have got an PCI based DAQ from ICPDAS PCI 1002 DAQ card i want to use with LAbView or LabWindows but how to use it i donot know please help me
(3,187 Views)
Hello;
To use a third party DAQ board with Labview or Labwindows, you need to know what DLL functions the board requires to be called so a DAQ task is accomplished.
The best source to get that information is the vendor of that hardware. Once you know what functions to call and in which order, you can use the Call Library Function of Labview to make the functions calls.
Hope this helps.
Filipe A.
(3,187 Views)
