does analog output and analog input use th same buffer
hi,
I would like to know if the AO write and AI read use the same buffer.I am using PCI6052E card with FIFO buffer of 2048 samples.I am performing a simulataneous AI and AO based on external trigger on PFI0.every time I do an AO write the AI read seems to be blocked.what could be the problem ?
thanks,
Shiv
(3,403 Views)
Hello;
Each DAQ task has its own FIFO, meaning that the AI has one FIFO, and the AO has another.
The problem is probably happening because you are using synchronous VIs to do the Analog Input. So, the CPU execution pointer get stuck inside the AI Read.VI untill the AI buffer is ready to be retrived. That might cause some synchronization problems.
The way to have that fixed is to use asynchronous VIs to do the AI side of your application. You can find some Labview shipping examples on how to do that at Analog Input->DAQ Occurrences.
Hope this helps.
Filipe A.
(3,403 Views)
