Power Connector of 9022 controler and 9870/9871 moduls
Hi, because we have to do our own cabling, we cannot use the standard power harness of NI. So can anybody tell me the designation/manufacture of the Power Connector of the CRio 9022 controler and also of the secondary power connection of the RS232 modul 9870.
Thanks in advance!
Peter
(5,666 Views)
Hey Peter,
For the power connector, I believe the original vendor is Sauro CTF but I'm not sure on the specifics of the number you would need. What is it about the standard harness that makes it unusable for your application? As long as the wiring and crimps you choose are capable of handling the current requirements of the controller, you should be ok with a different connector.
The supply line for the 9870 looks like one of Molex's microfit connectors. The 9870 Product Page indicates it as a "Microfit". I'd put my money down that it is part of the Molex Microfit 3.0 family. You can find the M/F connectors and M/F crimps at Molex's website, which is pretty user friendly.
Tim A.
(5,656 Views)
Hi Peter,
the cRIO-9022 used a connector from Sauro.
Order Number CTM049V8
http://www.sauro.net/asp/sez/pro/cmp/sch.asp?LIF=CTM&VER=9&VIE=04&MON=V&PAS=8&CUS=&VDMidr=6#
The power supply of the NI-9870 is a Molex 3.00mm (.118") Pitch, Micro-Fit 3.0 Header, 43045-0400, Dual Row
http://www.molex.com/molex/products/datasheet.jsp?part=active/0430450400_PCB_HEADERS.xml&channel=Pro...
Regards, Stephan
(5,645 Views)
