Problem with DAQmx and Real Time PCI-7041/6040E.
I have a problem with the Real Time card PCI-7041/6040E, I think it is properly installed because my software run with the traditional NI-DAQ. When I try to use the new DAQmx to acquire one signal, Labview doesn't see any device for de DAQ card 6040E.
Information, I work on Windows XP and LabView v7.0.0 (NIDAQ RT v7.0.0, NI-Serial RT v2.5.2, NI-VISA v3.0.1 and NI-Watchdog v2.0.0).
Could Labview RT run with new DAQmx ?
What can I do to use DAQmx with PCI-7041/6040E?
Thanks for your help !
(3,764 Views)
Hello V.Graf,
unfortunately DAQmx does not support Real-Time-cards yet. We are working on it but I can not say how long it takes. So,till now, there is no way you can use LabVIEW RT with the new DAQmx.
Sorry...
Peter Weber
NI Germany
(3,763 Views)
I refer to your posts because i am using the PCI 7041/6040E card as well but without any success to make it work. The problem I have already described in the following thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=120198
Would be nice if you had a look on it, maybe you can help me. BTW, the thread starts with a problem of someone else, the difficulties I encountered are to be found a little bit to the bottom of the thread's page.
Thank you!
Dirk Völlger
Darmstadt
Message Edited by ratschnowski on 07-28-2005 07:14 AM
(3,533 Views)
