code 8
Hi all I am using PXI 8186 embedded controller with real time OS, I have run my application for quite long time before, but yesterday after running the application for few hours the PXI rebooted and gave me a system error with the following error in the log file. can any one tell me what this means?
System log started Wed Jul 27 09:25:30 2005
*** REGISTER DUMP FROM EXCEPTION HANDLER (code 😎 ***
EAX = 0x002EEDE4    EBX = 0x002EA060
ECX = 0x001EB4F8    EDX = 0x00000017
ESI = 0x001EB4F8    EDI = 0x001EB6F8
EBP = 0x002EEE54    ESP = 0x002eeb74
CS = 0x0018  DS = 0x0020  ES = 0x0020
EIP = 0x00123fe2
Thread name: Enet Receive Thread
Thread stack base: 0x002ED000  stack size: 8192
Call Stack:
Level 1 :  Code pointer: 0x00142656  Stack Base: 0x002EEE90
Level 2 :  Code pointer: 0x0014858C  Stack Base: 0x00000100
Level 3 :  Code pointer: 0x0013DBFE  Stack Base: 0x00000000
DLLs loaded:
DLL: EMBLVIEW.EXE     First export address: 0x00300040
DLL: FTPSERVE.DLL     First export address: 0x002F3BE8
DLL: I8255X.DLL       First export address: 0x0029B6CD
DLL: LIBICONV.DLL     First export address: 0x00276430
DLL: LVRT.DLL         First export address: 0x00341B20
DLL: MXS.DLL          First export address: 0x009CC0C2
DLL: MXSDD.DLL        First export address: 0x01F84942
DLL: MXSEMB.DLL       First export address: 0x006C9E84
DLL: MXSIN.DLL        First export address: 0x009E6B5F
DLL: MXSUTILS.DLL     First export address: 0x006EE102
DLL: NICDRP.DLL       First export address: 0x045A60A3
DLL: NIDEVLDP.DLL     First export address: 0x019A9C3E
DLL: NIDIMP.DLL       First export address: 0x0076A99E
DLL: NIDMMU.DLL       First export address: 0x01910FE0
DLL: NIDMXFP.DLL      First export address: 0x01AC4FB9
DLL: NIDS.DLL         First export address: 0x0243FE99
regards
Arun
(3,585 Views)
Hello Arun,
                   This error has long been fixed and should not occur. What version of LabVIEW RT are you using? Did you change any settings? Try rebooting your system and running it to see if the error reoccurs. Let us know what you find.
RMM
(3,580 Views)
Hi
Thanx for the reply.
Am using LabVIEW 7.1 with the same RT module, also the embedded PXI has the latest software installed in it.
after restarting the PXI the application was running for all day with out this error, Can you tell me why this error occured? and what are the chances of this error occuring again?
Thanx a lot
Regards
Arun
(3,576 Views)
