Problems with IEEE 1394 Device and Realtime
I'm using Labview Real-Time Desktop, for a vision application.
I added a IEEE 1394 SBP2 Device in the PC, but after the start I get an error code:
"Failed to start IEEE 1394 SBP2 Device.
Error code = -1217"
Are there spezial BIOS Settings necessary?
Thanks.
(3,215 Views)
first i don´t find anything to error 1217. Look at following link how to run application on RT with imaq. Comes the error only in *.exe or also when running *.vi on RT ?
Can´t be that the driver don´t installed correct or the device has other ressource name and can´t find - good way is build a debuggable *.exe and test where the error is first occured - with highlight modus or error indicator
Hope these helps. Best Regards
(3,202 Views)
