04-03-2008 08:24 AM
I'm using Labview Real-Time Desktop, for a vision application.
I added a IEEE 1394 SBP2 Device in the PC, but after the start I get an error
code:
"Failed to start IEEE 1394 SBP2 Device. Error code = -1217"
Are there spezial BIOS
Settings necessary?
		04-04-2008
		07:07 AM
 - last edited on
		05-16-2024
		10:07 AM
 by
			Content Cleaner
first i don´t find anything to error 1217. Look at following link how to run application on RT with imaq. Comes the error only in *.exe or also when running *.vi on RT ?
Can´t be that the driver don´t installed correct or the device has other ressource name and can´t find - good way is build a debuggable *.exe and test where the error is first occured - with highlight modus or error indicator
Hope these helps. Best Regards
