Problems with large array and dll
Has anyone noticed problems with using larger arrays with a dll on RT?
I am using a dll files to generate a motion path for a 4 axis machine.  I use the Call Library Function Node to run the dll and pass in 4 arrays to store the points.  When the array size is 2500 and I run the dll on the host, everything runs fine.  When run on the target, the target disconnects and I have to reset it before I can connect again.  If I drop the array size down to 1000, the dll runs fine on the target.
Has anyone else had this problem?  I am doing something wrong or is RT limited to small arrays?
thanks
Message 1 of 1
(3,993 Views)
